How to change the settings of your cooling fan on Alpha & Delta?
userHead LattePanda 2020-07-15 22:58:35 9607 Views9 Replies
Compatible Model:
LattePanda Alpha
LattePanda Delta
Steps:
1.Press ESC to enter BIOS menu and navigate to “Chipset”, you will find Temperature Threshold. (The BIOS page will vary from model to model, and some versions have this temperature Threshold option under the Advanced menu) temperature threshold.jpg temperature threshold.jpg (249.17 KiB) Viewed 6517 times 2.Choose a lower starting temperature.
3.Your cooling fan will start to spin at a lower temperature to get better heat dissipation.
Answers:
The default setting for the fan on the board is: Start 70℃ Stop 60℃.
So your fan doesn’t spin if the motherboard temperature has not reached 70℃. By lowering the temperature of the fan in BIOS, the motherboard temperature can be controlled lower to achieve better heat dissipation effect.
