Latte Panda Delta i2s audio output
MrWoo 2020-09-08 21:28:28 2686 Views1 Replies I am using LP delta.
I want to use i2s of the expansion I/O in the figure below as an audio output. (3.5mm jack is not used)
The i2s input amp circuit was simply configured by purchasing a test board, but there is no sound at all.
Is there anything that needs to be set in LP delta? Attachments
LP delta board image.png (334.5 KiB) Viewed 1344 times
