Multiple Display with Docking Station - Lattepanda Delta
hackerchamp 2021-04-30 11:34:58 2370 Views1 Replies Hi.
I have a question about the USB-C -> Display Port capability. As far as I have seen in the documents it's possible to use an adapter at the USB-C slot to add one extra monitor/display. Is it also possible to use a dockingstation at the USB-C port with two additional display ports or hdmi ports?
For example this dockingstation (https://www.amazon.de/dp/B08GH86N4G/ref ... MHHBYTRC6A) has two hdmi ports. If I plug in this dockingstation to my lattepanda delta, will I be able to use these two ports with the one hdmi onboard? So that I can use 3 display at once
