Expansion Header - LattePanda Alpha
Chaowing 2021-05-04 08:24:46 2077 Views1 Replies Hello,
I want to be able to change function on some pin. Is there a document with each pin on the expansion header and the mode setting for each pin.
Also, is it possible to have access to I2C2 pin without using the Touch display connector.
