Alpha m3-7Y30 windows drivers
catmocca 2021-05-14 00:01:45 4050 Views6 Replies Hi
I have just had to reinstall windows 10 on my alpha, the m3-7Y30 seems to be the forgotten machine, ironic seeing as it was the kickstart model. YOu have install images for the other cpu's but not this one. So is there an image I have missed, or another that will do as well?
I have installed intel driver pack but still have several missing drivers
Base system device
PCI\VEN_8086&DEV_1911&SUBSYS_20158086&REV_00
PCI Data Acquisition and Signal Processing Controller
PCI\VEN_8086&DEV_9D31&SUBSYS_72708086&REV_21
PCI\VEN_8086&DEV_1903&SUBSYS_20158086&REV_02
PCI Memory Controller
PCI\VEN_8086&DEV_9D21&SUBSYS_72708086&REV_21
SM Bus Controller
PCI\VEN_8086&DEV_9D23&SUBSYS_72708086&REV_21
Unknown
ACPI\GDIX1001\4&1CB66D28&0
ACPI\INT3400\2&DABA3FF&1
ACPI\INT3403\SEN3
USB\VID_8087&PID_0A2A\6&29567932&0&1
And despite trying many times the auto power on bios doesn't work. Wake on clock would be nice too.
Any help you can give would be appreacited
Base system device
SM Bus Controller
Unknown
ACPI\INT3403\SEN3
