I can't manage to get the builtin arduino to upload!
LE_E_DEV 2021-07-10 04:20:12 5674 Views6 Replies Btw this is my first post here.
I was just having a normal day when I got an idea to make a gamepad for my LP Alpha. But like every time, nothing worked my way. The code can compile but I just can't manage to get it to upload. And thats where the troubleshooting started.
Here is the list of things I did:
1. reseting the arduino with the button
2. rebooting the LP
3. make sure the right port, board is selected
4. reinstalled the driver for the arduino
5. change the bootloader
Here is the error message I get:
Also I know that there are various posts with a simular topic but they all seem to not help.
2. rebooting the LP
Arduino: 1.8.15 (Windows 10), Board: "Arduino Leonardo"Please!! Just anybody please send help. I am sick of troubleshooting this strange error.
Sketch uses 5610 bytes (19%) of program storage space. Maximum is 28672 bytes.
Global variables use 211 bytes (8%) of dynamic memory, leaving 2349 bytes for local variables. Maximum is 2560 bytes.
Forcing reset using 1200bps open/close on port COM10
PORTS {COM3, COM5, COM6, COM10, } / {COM3, COM5, COM6, } => {}
PORTS {COM3, COM5, COM6, } / {COM3, COM5, COM6, } => {}
PORTS {COM3, COM5, COM6, } / {COM3, COM5, COM6, COM10, } => {COM10, }
Found upload port: COM10
C:\Users\LattePanda\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\LattePanda\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega32u4 -cavr109 -PCOM10 -b57600 -D -Uflash:w:C:\Users\LATTEP~1\AppData\Local\Temp\arduino_build_172540/sketch_jul08a.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\LattePanda\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM10
Using Programmer : avr109
Overriding Baud Rate : 57600
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : butterfly
Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
Found programmer: Id = "F"; type = @
Software Version = �.u; Hardware Version = �.
avrdude: error: buffered memory access not supported. Maybe it isn't
a butterfly/AVR109 but a AVR910 device?
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: error: programmer did not respond to command: leave prog mode
avrdude: error: programmer did not respond to command: exit bootloader
avrdude done. Thank you.
the selected serial port
does not exist or your board is not connected
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
