Bypassing the power button while turning the LattePanda on
anonymous 2021-07-16 20:52:49 3369 Views5 Replies I am using LattePanda in a commercial product I'm developing, and as mentioned in your documentation for LattePanda
"3.When the LED indicator turns off, press and hold the power button for one second to turn on the LattePanda. You should see the LED indicator light up again."
I would like to know if there is any way to bypass the power button and directly turn the LP ON on power supply to make it easy for my customers to use it. Thank you!
