Startup Time Preset
beggiator 2021-07-30 11:55:50 3872 Views1 Replies I just recently started using my new LattePanda 4G/64GB. It has been working great so far for what I intend to use it for (I cannot disclose the purpose of the board).
One issue I had with it, that was solved by reading a couple forum threads here, was startup occurring without having to push the power switch after the initialization process. It was easy to do in BIOS.
What I want to know is if I can set a time of day so that the LattePanda turns on by itself. Is this possible in BIOS? If so, I was unable to locate the setting.
For example, I want to know if there is a setting that I can use to boot up the LattePanda by changing this setting to say 15:00. At the local time 15:00, the power supplied LattePanda would turn on by itself without any user interaction.
Thanks.
Thanks.
