Lattepanda alpha Do not power up
thp_34GM 2021-08-17 00:24:39 1936 Views1 Replies Hello
I have a latte panda alpha M3-7y30RAM 8Gb since 2019 that worked well until last week.
The LP does not power up anymore with it's power supply.
I tried some solutions proposed on ht eforum without success.
I tried to connect the 12V conctor to a programmable power supply and I can see the Amps growing with the voltage and one of the 4 V3605 mosfet component on the PCB becomes very hot.
Did someone already experienced this problem. Do you think that the problem could be the v3605 or somewhere else on the board?
Thank you for your help
Thierry Attachments
Thierry Attachments
