CPU 100%
nbl7 2021-10-31 01:49:08 2002 Views1 Replies Hello there,
I just bought a new LattePanda Delta from www.dfrobot.com with a Windows Licence installed.
I did not install any app and I did not change anything on Windows config, however the CPU is always 100% even without doing any work.
The temperature is around 50°C and the room temperature is below average.
where they are saying the LattePanda may require some active cooling. But I don't understand why, Shouldn't the installed fan enough at least for easy work?
Thank you for the support. Attachments IMG_6563.jpg (213.33 KiB) Viewed 853 times
