help with Arduino Leanardo on Alpha
userHead dablitz1 2022-03-03 06:28:17 1852 Views1 Replies
I am trying to get this to work. I know I have hooked everything up correctly. I am currently using Ubuntu 20.04 with the Arduino IDE installed. I have a INA219 High Side DC Current Sensor. the SDA and SCL are properly connected to D2 and D3 on the Arduino pinset. Using the Arduino IDE I have selected the Arduino Leonardo board and the ttyACM0 as the USB port. I am still learning the code on this but could someone give me some assistance.
import time
import board
from adafruit_ina219 import ADCResolution, BusVoltageRange, INA219
i2c_bus = board.I2C()
ina219 = INA219(i2c_bus)
print("ina219 test")
// display some of the advanced field (just to test)
print("Config register:")
print(" bus_voltage_range: 0x%1X" % ina219.bus_voltage_range)
print(" gain: 0x%1X" % ina219.gain)
print(" bus_adc_resolution: 0x%1X" % ina219.bus_adc_resolution)
print(" shunt_adc_resolution: 0x%1X" % ina219.shunt_adc_resolution)
print(" mode: 0x%1X" % ina219.mode)
print("")
// optional : change configuration to use 32 samples averaging for both bus voltage and shunt voltage
ina219.bus_adc_resolution = ADCResolution.ADCRES_12BIT_32S
ina219.shunt_adc_resolution = ADCResolution.ADCRES_12BIT_32S
// optional : change voltage range to 16V
//ina219.bus_voltage_range = BusVoltageRange.RANGE_16V
// measure and display loop
while True:
bus_voltage = ina219.bus_voltage // voltage on V- (load side)
shunt_voltage = ina219.shunt_voltage // voltage between V+ and V- across the shunt
current = ina219.current // current in mA
power = ina219.power // power in watts
// INA219 measure bus voltage on the load side. So PSU voltage = bus_voltage + shunt_voltage
print("Voltage (VIN+) : {:6.3f} V".format(bus_voltage + shunt_voltage))
print("Voltage (VIN-) : {:6.3f} V".format(bus_voltage))
print("Shunt Voltage : {:8.5f} V".format(shunt_voltage))
print("Shunt Current : {:7.4f} A".format(current / 1000))
print("Power Calc. : {:8.5f} W".format(bus_voltage * (current / 1000)))
print("Power Register : {:6.3f} W".format(power))
print("")
// Check internal calculations haven't overflowed (doesn't detect ADC overflows)
if ina219.overflow:
print("Internal Math Overflow Detected!")
print("")
time.sleep(2)
this is my error
battery.ino:1:1: error: ‘import’ does not name a type
I am at a total loss.
