a lattepanda 864s turns off with minimal stress
anonymous 2020-02-05 11:58:40 5911 Views8 Replies I have the lattepanda 864s. I have the temperature of the fan settings in the bios at the minimal. I also have this power supply:
https://www.jameco.com/shop/ProductDisp ... Id=2226038
I supply the power via the CN2 port. The random problem I present is when I make some charge of work, for example run virtual box or copy files the lattepanda is when automatically turns off like if crash. This is not always and is only just in some occasions. If there is no stress I can leave turn on for days the lattepanda and no problem at all. What can be the problem of the shutdowns? Or can I try to solve?
Thank you
Thank you
