Broken fan
ChrisTaylor 2022-09-05 20:27:33 1543 Views1 Replies Started using the LattePanda 3 Delta as a server tonight and noticed that the fan is not spinning on it. If I help it spin with my finger it will get going and eventually stop spinning. When running a CPU stress test in Linux, it overheats easily and the CPU throttles down to 800 MHz.
Does anyone have an idea for a good replacement cooling solution?
