Boot Linux from SSD On 3 Delta
userHead joeO24 2023-01-11 11:38:17 2167 Views1 Replies
I cross posted this on the Latte Panda forum on Reddit
I just took delivery of a 3 Delta yesterday. I bought it with the intent to run Linux Mint, so I didn't get an activated Windows. Linux Mint is derived from Ubuntu, which is supported on the Panda 3 Delta. I installed a Samsung EVO 970 1TB SSD in the M.2 "B" key slot.
I was able to boot the Mint install disk from a USB drive. Then I installed Mint on the NVME SSD. But I cannot get the system to boot from that SSD at all. In the BIOS, my UEFI boot order is NVME-USB-Windows-Network. The LEGACY boot order is: NVME-USB-Hard Disk-Network. But restart does not recognize the O/S stored on the SSD, either with UEFI or Legacy. I tried disabling the EMMC, but then the system would not boot at all (the USB drive had been removed, but the SSD was in).
I'm sure there is an install parameter for Mint that I missed, or that there is a BIOS setting that is wrong, but I am reluctant to use trial-and-error on the BIOS settings, as that "and-error" part may turn the Delta 3 into a brick. Also, although I wanted Linux from the start I am reluctant to overwrite the non-activated Windows as that is the only O/S that starts for the moment, if you don't count USB boots.
