Microsoft SQL Server 2019 on Latte Panda 3 Delta
userHead pa 2023-01-17 23:03:45 1590 Views1 Replies
Hello there,
I was wondering if anyone has tried or knows if Latte Panda will be able to handle the Database Engine in SQL Server 2019 (which only runs on x64 bit architectures). or if it can run an older version of MS SQL Server 2008?
I intend to run a VB.NET WinForms app with Windows Task Scheduler and MS SQL Server.
Thank you!
