How to disable the MIPI interface on Lattepanda?
userHead Tonny12138 2023-03-07 22:52:41 1836 Views1 Replies
To disable the MIPI interface on Lattepanda, follow the steps below:
1、Press the ESC/DEL key to enter the BIOS menu.
2、Go to "Chipset" in the menu.
3、Navigate to "North Bridge" and select it.
4、Look for "IGD-LCD Control" and select it.
5、Choose "MIPI DSI" from the options.
6、Finally, select "Disabled" to turn off the MIPI interface.
By following these steps, the MIPI interface on your Lattepanda board will be successfully disabled.
