10.1" eDP White Screen Issue
Couchy 2023-03-22 06:13:12 1198 Views4 Replies I'm trying to connect a 10.1" screen through the eDP connection on the Delta 3, but I'm only getting a white screen.
The screen fits the guideline of 3.3v and uses a 30 pin two way connector.
I'm using a Panasonic VVX10F011B00,
https://www.panelook.com/VVX10F011B00_Panasonic_10.1_LCM_overview_21047.html
Below is a comparison of the pin outs of the delta and the screen, the pinouts are from Delta but I believe they are the same as Delta 3.
It's worth noting that pin 30 started smoking when plugged in, as it was csi_usb straight to gnd, I cut this cable to remove this issue.
Any help would be greatly appreciated, and I'd love to add a 10.1" to the list of working screens for the Latte Panda!
AI ProjectsAI ProductsMore LattePanda ProjectsLattePanda BlogsLattePanda DocumentsView LattePanda Products
