Lattepanda Delta 3 - 100% CPU load on core 0 caused by NVME SSD
userHead AndrewH 2023-04-27 15:31:59 2279 Views4 Replies
Hi, I've recently set up my Kickstarter Lattepanda 3 Delta. I installed an NVMe SSD, booted it, and let it run all the suggested windows updates including an update to windows 11. When I came back to use the system properly, I noticed that CPU core 0 is always maxed-out at 100%:
Looking at task manager, the CPU load was not attributed to a windows process, so I assumed it was caused by CPU interrupts. Using LatencyMon (https://www.resplendence.com/latencymon), I have confirmed this is the case (note the very high execution time for ACPI.sys):
I worked out that if I remove the NVME SSD, the issue goes away. I have tried 3x different SSDs from Samsung, Crucial and Western Digital. All disks work in other systems without creating problems. When the SSD is installed, putting the CPU0 at 100%, I can read and write to the disk with no observed problems.
If I boot Windows into safe mode, the 100% CPU issue goes away and the disk still works normally (ni safe mode, none of the disks appear in Task Manager, but it's still accessible through Explorer):
To resolve this issue, I have tried the following:
+ Unplugging all attached devices (other than the USB power brick and HDMI).
+ Installed the Intel Driver & Support Assistant (https://www.intel.co.uk/content/www/uk/en/support/detect.html), and letting it install all recommended driver updates.
+ Explicitly installing the latest drivers Delta 3 drivers (As hosted at https://docs.lattepanda.com/content/3rd_delta_edition/drivers_and_software/).
+ Updating the BIOS (As hosted at https://docs.lattepanda.com/content/3rd_delta_edition/bios/)
+ Setting the Windows power profiles to “Balanced”, “High Performance” & “Power Saver”.
+ Tried setting the PCI Express > Link State Power Management to “Off”, “Moderate" and “Maximum power savings”.
+ Tried disabling as many devices a I dare in device manager.
+ Completed a “Reset this PC” process, to take it back to the original state.
+ Resetting the BIOS to defaults.
+ Installing windows 10 on the NVME SSD and booting off that.
None of these steps have resolved the issue. I would be grateful for any advice anyone has as to what my next steps should be. Thank you in advance.
