Solution to run a hosted network with Latte Panda 3 and Win10
Peter.Litsegaard 2023-06-21 20:44:59 1734 Views1 Replies Hi!
I'm using a Latte Panda 3 to control my astrophoto equipment and it does a great job doing that. However, I need to be able to use the hosted network (under Win10) but unfortunately the built-in WiFi module of the LP3 does not support this, entering "netsh wlan show drivers" results in "Hosted Network Supported : NO" :(
This is a problem for me as I usually have no WiFi network (router connected to wan) on the sites I'm visiting. All I want to do is to be able to connect to the "hosted" network of the LP3 and then connect other devices using WiFi.
If this is not possible does anybody know of a high performant M2 B Key card that I can use for this OR an equally performant external WiFi access point which I may connect using USB?
My last resort would be to use a cat 5/6 cable but this is awkward especially when the temperature reaches -10 to -15 degrees C (yup - the Panda works fine in these temps).
I really hope somebody is able to help me out here and many thanks in advance.
