Delta 3 upgrade to Windows 11... Free?
billymac 2024-05-19 07:13:43 3068 Views1 Replies My Latte Panda Delta 3 came with Windows 10 installed
Windows 10 IoT Enterprise LTSC
I previously installed Windows 11 using the installer downloaded from DFRobot
When I tried to activate it, I could not, I believe due to the type of OEM version I had installed.
I had to reinstall Windows 10
That doesnt make sense to me because they advertise it can be upgraded to Windows 11, but if I need to pay for a 11 license, the money I paid for Delta 3 including windows license would be money wasted.
I would like to try again.
If I run the Windows 11 Installation assistant, it says This PC meets the minimum requirements tro install Windows 11.
...But I am afraid I will run into the same license issue if I do install it.
Also, I assume it is better to use the installer from DFRobot which I believe is tweaked for Latte Panda.
Please help...
