How to Generate a UUID for LattePanda Models
userHead LattePanda 2024-05-24 23:16:10 2973 Views3 Replies
Introduction to UUID
A Universally Unique Identifier (UUID) is a 128-bit number used to uniquely identify information in computer systems. However, not all systems come with a UUID by default. For instance, LattePanda models, with the exception of the LattePanda Mu(LattePanda Mu comes with a UUID already), do not have a pre-assigned UUID. To address this, users can generate a UUID using a provided tool. This tutorial will guide you through the process of generating and activating a UUID for your LattePanda device.
Prerequisites
- LattePanda model (excluding the LattePanda Mu)
- Download the attached tool for generating a UUID
Instructions
Step 1: Prepare the Tool
Unzip the attached file containing the UUID generation tool. Locate the executable file named `DMIEDITx64.EXE` and run it.
Step 2: Access UUID Settings
Navigate to `[Type 001] -- System Information -> uuid`. Here, you will find the current UUID setting for your system. To modify it, double-click on the `UUID` field.
Step 3: Generate UUID
A dialog box will appear with an option to "Auto Generates system UUID." Select this option to allow the tool to automatically create a new UUID for your LattePanda.
Step 4: Update System Information
After the UUID has been generated, you need to update the system information to reflect the change. Click on "Update -> Current Type" to save the newly generated UUID to your system's DMI records.
Step 5: Activate the UUID
To complete the process and activate the UUID, you need to restart your system. Once the system has been restarted, the new UUID will be in effect and your LattePanda will have a unique identifier.
Verifying the UUID
To confirm that the UUID has been successfully generated, you can use the following steps:
1. Press WIN+R on your keyboard to open the Run dialog box.
2. Type cmd and press Enter to open the Command Prompt.
3. In the Command Prompt, type wmic and press Enter to access the Windows Management Instrumentation Command-line tool.
4. Next, type csproduct and press Enter.
5. You should now see the UUID information displayed on the screen. If the UUID shown matches the one you generated, then the process was successful.
Conclusion
By following these simple steps, you can easily generate and activate a UUID for your LattePanda device. This UUID can be used for various purposes, including system identification and ensuring that your device has a unique identifier that distinguishes it from others.
icon DmiEditWin64.zip 3.14MB Download(0)
