LattePanda 3 Delta failed to auto-start
userHead Martin.Zhu 2024-07-01 13:35:01 2278 Views4 Replies
What I expect:
I would like to have my LattePand 3 Delta device auto-start after the following scenarios:
1. Power shortage --> Device off --> Power comes back --> Device auto-starts
2. Battery voltage drains below to the operational voltage --> Device off --> Charge the battery back to operational voltage (keep the battery connected to the device during this process) --> Device auto-starts
What I've done:
I modified the power management settings in BIOs, and set it to "Power On".
What is happening:
The configuration will handle scenario 1, which I mentioned above.
Doesn't work for scenario 2.
Questions:
1. The battery always connects to the device even when it is low voltage. Is it because the device couldn't recognize the state (voltage) changes and failed to trigger the auto-start?
2. Is there any way we can achieve scenario 2 via system setting/software?
3. Is there any way to achieve it via simple hardware adjustment?
I really appreciate any help you can provide.
Martin.
