Project OpenSource CCTV NVR
RoninByte 2024-09-04 07:45:15 4318 Views5 Replies An open source CCTV NVR (Still WIP)!
My Background
I am always into tinkering and tearing stuff open to see how things work ever since I was young. I am currently a student studying another subject. I have no background in making PCBs, I've never attempted it before but gave it a shot as an enthusiast who loves to learn new skills, so i took on designing a PCB.
How the project came to be
I had a well known branded DVR from a company that worked well for the first year however soon after the DVR started to-do funky stuff like splitting the hard drive and turns off randomly etc and the fact only one hard drive could be added. Fed up with issues that were occurring i ventured out to make my own NVR that was upgrade able and i came across the Lattepanda MU event (https://www.lattepanda.com/forum/topic/335025), i submitted my idea and it was accepted.
Photo Of PCB:
NVR Requirements
4 x sata ports
4 x power for sata
2 x USB 3 ports for external storage
2 x USB 2 ports for other peripherals
2 x M.2 Slots (1x Specialized M.2 slot designed to take dual TPU card like the coral edge Dual TPU 1x Normal M.2 for boot drive)
2 x Ethernet Ports (1gbps currently but intend to use 10gbps one)
1 x CPU Fan Header
1 x 12v System Fan Header
1 x HDMI
1 x USB-C for power ( may be possible to turn it into DP port aswell for both video out power saving space on the board)
1 x 12v DC barrel Jack
Where is the project files
Reason for using Github. Is that i need the communities help, pull requests to complete and improve the boards are open for you to submit, this is because i am running out of time as i will be going back into my studies and i am not an electrical engineer by trade, so anyone with experience in this is welcome to review and give constructive criticism on the board
Checklist
I used the Lattepanda Lite Carrier to make my board
- Removed some unneeded stuff [Done]
- Add Screw Holes for the NVME slots [TO-DO]
- Possibly remove the ref clock amplifier and splitter for a crystal oscillator for simplicity reason [TO-DO]
- Add Sata power header [TO-DO]
- Complete the traces [TO-DO]
- Add 12v Fan header for system fan [TO-DO]
- Switch to 10gbps Ethernet [TO-DO]
- Make a case [TO-DO]
