Recovering system image (W10 LTSB)
Tom.Kohl 2024-09-06 02:19:19 1976 Views2 Replies Hello,
we have several Pandas v1 (4G/64G) with Win10 Enterprise (LTSB 2016). Now I would like to create a backup image that we could use a backup and also install on other Pandas to have exactly same setup on all devices.
I followed this guide https://www.lattepanda.com/forum/topic/313664 to create a system copy to a network location. Now I have a folder "WindowsImageBackup" in there. The problem is that the recovery does not work.
1) If I create install media using the guide here https://docs.lattepanda.com/content/1st_edition/os/#windows-10-enterprise-for-commercial it completely reinstalls and DELETES all data WITHOUT asking!!!
2) If I select Troubleshoot, Advanced options, System Image Recovery in Control Panel, it does not allow me to select the created image. If the image is on USB, the image is not detected at all by recovery tool. If image is on network (Samba) and I try login to this network location, it ends up with "Specified logon session does not exist" error.
3) If I tryto do restore directly from "Backup and Restore" tool and I select the network location (cannot select USB), it tells me "Windows was not able to find aby backup sets".
Any ideas how to recover the system with the created system image?
