Problem with RS232 on LP 3 Delta using Windows
Christian.Drüke 2024-09-06 05:39:23 2027 Views4 Replies Hi,
I have problem to communicate with other devices using the onboard RS232 interface. To test the communication I used an external RS232 USB adapter connected to an other PC.
I used Putty on both side, the LattaPanda and the other PC, to connect to the serial ports using the default settings provided by Putty. I expected that the input on one device will be shon on the oder device an vice versa, but its not. For the test I pressed six time the letter "a" into the Putty window on each of the machines. The output is show in the following images.
Output LattePanda ![]() | Output other PC |
The interesting part is that the issues are not incorrect in the same way.
The LattePanda is running the lates Windows 11 update, but I got the same behaviour with the Windows 10 installation as well. The Bios is the latest version.
I installed all drivers from the driver page for the LattePanda 3 Delta and I have uninstalled the Communication device using the Device Manager und force the system to use the new driver. I'm not sure if this did work, because I thought the driver I needed was the "intel Serial IO Driver" but it uses a Microsoft Driver (see the image below). I tried to force it to use a driver from the "intel Serial IO Driver" zip file, but it says that there is no compatible driver available.
Do I miss something. Is there an other driver to use or some settings to change?
Thanks in advance
Christian
