18650 Battery for Latte Panda Sigma
userHead Sebastián.Barbuzano Narváez 2024-10-30 03:13:43 1984 Views1 Replies
Hello hello!
I have a question, probably "typical" for a non-electrician hahaha.
I'm thinking of building a battery for the Latte Panda Sigma.
I have searched about the 18650 batterys (5 uds of 3'6V 3500mAh 5A in serie, which makes a general battery of 18V and 3500mAh 5A).
As you can see, it has a voltage of 18V and a maximum discharge of 5 amps, which allows it to cope with maximum consumption peaks of 90W (recommended on instructions).
My question is: does this paragraph refer to whether, by connecting the battery through the JST PH2.0-8Pin port, and connecting the original adapter to the latte panda through the DC Jack port, will I be charging my battery?
Thank youuu!!!!!
Best team, latte panda :)
