[Geiger Counter Module] How can I convert interrupt counts to nSv/h or µSv/h?
JaneYu 2024-12-23 09:21:04 3749 Views1 Replies How to convert from interrupt count to nSv/h or uSv/h?
2024-12-23 09:22:42
JaneYu
We provide the convert process in our Github repo:
https://github.com/cdjq/DFRobot_Geiger
The default is high level. When the Geiger tube generates a signal, it outputs a pull-down pulse with a pulse width of about 300μs.
CPM is the pulse count per minute. In fact, it does not need to be counted for one full minute. For example, if there are 10 pulses in 20 seconds, then 10*(20/60)=30CPM
Finally, the radiation value is calculated using the calculated CPM (Count per minute)
JaneYu
