USB Hub Detection Delay on Type-C Port – LattePanda Delta 3
Udhayakumar.Karthi 2025-03-05 12:41:27 1414 Views1 Replies Hi everyone,
I'm facing an issue with my LattePanda Delta 3. When I connect a USB hub (both USB 3.0 and USB 2.0) to the Type-C port, it takes about 10 minutes to get detected. I’ve tried different hubs, but the problem persists.
Is there any BIOS setting or driver update required to enable the Type-C port to function properly as a USB port? Or is this a known issue with a possible workaround?
Any help would be appreciated. Thanks!
AI ProjectsAI ProductsMore LattePanda ProjectsLattePanda BlogsLattePanda DocumentsView LattePanda Products
