These Pinout are the IO of CC2540. Blunos has Atmega328 chip which provides the most useful I/O.
userHead JaneYu 2015-01-22 13:02:48 146 Views7 Replies
2016-03-21 18:21:37
Are the TX/RX 5V tolerant??
it is better not, or it will damage the chip.
2016-03-28 16:03:47
2016-02-17 11:22:45
Hi, which android app you are using? in android, it exists bluno basic demo. Try connect it with the app directly
2015-10-29 20:58:51
How can I change the parity of UART with AT command?
I tried with AT+UART such as AT+UART=9600,8,E,1 but it doesn't work.
Does the AT command set in your firmware only support changing the baud rate?
My project using this board is stuck at this point, Help!
2015-04-15 19:44:20
Still waiting response... I am also interested about what language/environment should be used to program it autonomously. No information at wiki or forum http://www.dfrobot.com/foru... yet
The internal firmware is not completely stable, so we are still working on it. So the related developing resource will be opened in the future.
2015-04-16 14:15:58
2015-01-23 08:36:32
Thanks. Interesting, ... but out of stock :(
