Is this compatible with B+ and raspberry pi 2.0?
JaneYu 2015-03-04 17:04:20 24 Views9 Replies Is this compatible with B+ and raspberry pi 2.0?
This works on the Leonardo because the Leonardo board has multple serial ports, which can be seen when you call both Serial.begin(9600) and Serial1.begin(9600). However, the raspberry pi only has on available serial port. Basically you can think of this as the Leonardo has two lanes for communication , while the pi only has one and therefore this code attempts to use two lanes but can not due to a lack of hardware.
JaneYu I'm not using the PI, the Xbee is on the shield and the shield is powered via USB. Since it is not even mounted on the PI, the PI is irrelevant. Are you saying that the Xbee only works directly from the PI?
Is it compatible with the raspberry pi 3?
JaneYu Yes, RPi 3 has the same pin map, so it is compatiable
There is an DS1307 RTC module in our website, you can have a look at its wiki, I think the usage there would help you with your problem https://www.dfrobot.com/wik...
JaneYu Hi DFRobot Support,
Thanks, I think that clears everything up. I was trying to access this directly through the Arduino as I thought it would have been like the DS1307 attached to a Datalogger shield, but if I understand the link correctly this is more for the Raspberry pi and I get its output over the i2c. Thanks, I haven't had time to try it out yet but it sounds easy enough.
Would like to communicate serially between the pi and arduino. Is there documentation for this? Are the Rx & Tx not connected? There are pins on the board; are they not connected?
We can communicate via USB cables using "serialPort": "/dev/ttyACM0". Tried directly with "serialPort": "/dev/ttyAMA0" but this did not seem to work.
JaneYu Hi, please check this one: it is compatible with B+/2B/3B https://www.dfrobot.com/ind...
JaneYu
