when this items are ready? i really needed it to buy this 10 DOF soon
userHead JaneYu 2015-03-04 18:56:41 19 Views7 Replies
2016-08-01 19:20:55
Hello, I have a simple question about this sensor.
First, whenever I try to use the example code, I cannot upload this dang code.
Second I also tried the other example that other guy linked on the comment and it still has draft value, I mean its freaking going up like there is no end of axis or something.
Do you have any idea to get the correct example for this sensor?
2016-05-27 21:04:20
Hello! A have a question: are you going to publish code for arduino, where all 3 sensors will be using. I meen, now your Arduino code uses raw values only from accelerometr and gyroscope, but it doesnt uses magnetometr values to complex and correct the gyroscope. That's why I have a drift on my pitch data. Also, that code have some comment parts of code, needed to use that values from magnetometr, but its not correct in some places..
Thank you.
2016-05-16 13:18:09
What is the logic level for I2C, 3.3V or 5.0V?
3.3V and 5V are both OK, it is wide range voltage input
2016-05-22 12:33:14
2016-03-28 10:10:41
Please check the wiki for the sample code: http://www.dfrobot.com/wiki...
2016-01-28 14:17:46
I am sorry, there is no Raspberry resource.
2015-10-12 06:57:09
Hi, what's the maximum refresh rate I can get with this 10dof imu?
