hi, how to make a compensation temperature code for phmeter?
JaneYu 2015-03-07 21:08:15 21 Views2 Replies hi, how to make a compensation temperature code for phmeter?
2015-04-22 04:03:05
JaneYu
yes, it works if this applied directly reading ph conversion after calibration whithout temp compensation.
But your link https://www.dfrobot.com/wik... is more easy because temperature compensation is applied during calibration.
Thank you very much!
JaneYu 2015-04-16 02:44:52
JaneYu
Hellos, can this electrode be used to replace the elecrode from the ANALOG pH METER PRO (SKU: SEN0169) after the first year?
JaneYu
