Hi !Can i drive two of these http://www.xq-power.com/XQ-... motors using this driver on an arduino ?Thanks.
userHead JaneYu 2015-03-12 00:05:05 23 Views12 Replies
Hi !
Thanks.
2016-07-29 20:21:45
Hello, thank you for the answer. the offset position save is very important for all robot.
- I bought this controller because the thought that has the same functions as dfrobot ssc32.
- will take some upgrading?
- I can drive servo 270 degress?
-My servos is HV (7.4v), work with this board?
2016-07-27 12:30:00
hello, I want to ask you something. Can I save the offset position to this board? I could do it usbssc32 (dfrobot version) with lynxmotion program
2016-07-14 09:58:36
The 360 degree servo, it works like a motor, you can control its speed and direction, but not its stop angle. this is the difference, but the control method are totally same
2016-07-11 13:19:00
Recommend the other baudrate, such as 57600 or 38400.
2016-07-05 22:08:24
Can this unit be used for continous rotation servos? If YES - how? Need to know before buy
2015-10-28 19:09:20
This is an extended function, it could record the motion, and work without any other device. But this feature is not finished now. Maybe in the next version.
2015-09-29 16:25:08
Hi, please change the baudrate to a low level. like 9600,
2015-08-27 19:12:29
It seems that that download file has been broken, could you download it again?
2015-05-28 11:12:21
It is OK, It could stand this voltage. I'll update its schematic later.
2015-05-27 18:10:42
Hi, Servo power port is a separate power supply. It doesn't matter with 7.4V power support.
2015-03-13 11:14:00
Of course! You could check the command on the wiki page.
2015-03-13 11:13:10
XQ-S56 looks like a standard servo, It should be supported.
