This is a very interesting pack. However, I can't find the Rubber wheel and the coupling weight and it is crucial for my senior project.
userHead JaneYu 2015-03-26 19:19:37 23 Views7 Replies
2016-01-25 10:31:25
Hi, I afraid it will be a problem with motor driver and RPi, their operating voltage are totally different. But you can add more modules like this shield. http://www.dfrobot.com/inde... Or, you can also search other way to driver the motor. try google "Raspberry Pi with motor".
2016-01-22 12:23:16
Of course, Actually I recommend you tu use Arduino as its microcontroller. Recommend our Bluno (With On-board Bluetooth) It is quite simple comparing with RPi. And you will need high performance motor driver like this http://www.dfrobot.com/inde...
2015-09-16 05:13:54
could you recommend a motor controller for this kit? using an arduino uno microcontroller. Thanks
2015-06-06 04:42:13
Could you guys tell me more detail on Motor specification?
Resistance, Impedance...?
Thank you very much!
Hi, this is motor l;ink, you can check here: http://www.dfrobot.com/inde...
2015-06-10 15:35:00
2015-04-01 05:44:52
what is the max weight this kit can carry?
2015-03-27 15:06:36
The wheel is 0.3kg each, and 2 wheels + connectors are 0.68kg in all.
