I bought this an just put it together. It went together very easily. Some soldering required for wire connections to motor. I have not hooked up an Arduino yet but the resources ma...
JaneYu 2015-04-22 23:18:42 10 Views4 Replies I bought this an just put it together. It went together very easily. Some soldering required for wire connections to motor. I have not hooked up an Arduino yet but the resources make it look easy enough!
Is it possible to get this robot chassis with a powerful motor with encoder ?
JaneYu Hi any recommended motor encoders to use with this kit ?
JaneYu Hi,sorry for my previous reply, please check this link: https://www.dfrobot.com/pro...
The AA batteries doesn't provide enough current (2.4 Amps only on short-circuit Duracell batteries), while single motor stall current is 2.8A. This oftenly causes VCC to drop below critical levels and restart logic, e.g. XBee resets connection when switching left to right model rotation. Also oftenly AA current not enough even to turn left or right. You should warn customers about that.
JaneYu
