Hello DFRobot,I just needed information before buying this kit : I have a project of building an automatized plants-watering system (according to soil moisture sensors) but for fou...
JaneYu 2015-09-08 03:52:27 20 Views8 Replies Hello DFRobot,
I just needed information before buying this kit : I have a project of building an automatized plants-watering system (according to soil moisture sensors) but for four plants.. the fact is : I don't know which controller can handle 4 relays & 4 sensors..
(I also want to put an interface onto it with my raspberry as a wireless server)
I'm very new to electronic's world so..
Thanks a lot for you consideration & wishing you a good day,
Jeremy
The xbee socket on the control board is compatible for wifi bee ESP8266, you can follow the instructions of ESP8266 wifibee https://www.dfrobot.com/wik...
JaneYu So, cool unit and I like it. Got mine up and working. I'm wondering about powering options. How I get this setup to not have to use batteries and set it up so it's got the proper powering by plugging into the wall. Thanks.
JaneYu How can I pass the wifi settings to the wifibee though?
The XTCU software won't see the wifi bee (as per its guide),
On the guide here - http://www.dfrobot.com/wiki...
I have tried the Ardruino server example and replaced serial with serial1 (other then the printIP command).
It doesn't appear to be doing anything :(
JaneYu Hi, I purchased this kit along with a wifi bee.
Is there anyway to configure the wifi bee with just the auto flowering control board. Or am I still required to use xbee usb adapter?
Any help,would be appreciated :)
JaneYu We got the new board this morning! Thank you so much for your kind and quick help! Now, without this USB connection problem, it should work perfectly :D
Nous avons reçu la nouvelle carte ce matin! Merci beaucoup pour votre gentille aide! si rapide! Maintenant, sans ce problème de connectique USB, ça doit fonctionner parfaitement :D
JaneYu Hi Mathilde, sorry for the inconvenience. We found this issue in the last batch, and it should be fixed now. You could contact our techsupport guys, let them help you to fix this problem.
JaneYu Hi, thanks for you reply! I didn't buy the board on your website, but via "L'impulsion" which is a french store. Is it a problem?
