What kind of motor driver would you recommend? It looks like any driver has to be rated for at least 3A, so does this put the Romeo out of the question?http://www.dfrobot.com/inde....
userHead JaneYu 2015-05-03 06:30:40 101 Views5 Replies
2016-04-10 11:07:13
What would be the best way to mount the motors if you're not using one of the platforms?
2016-03-16 21:53:34
How many pins does the motor use to talk to the microchip?
Two, but actually, you will need a motor driver first. Recommend this one. http://www.dfrobot.com/inde...
2016-04-11 17:05:35
2016-03-03 02:54:14
What is the gear ratio of this motor?
2015-10-23 14:11:19
No, just power will be OK. But if you find there is a large noise, you could add a capacitor on the motor pins
