Note: 360 degree servomotor works like a motor, you could control its speed and direction, but not angle.
JaneYu 2015-05-04 17:30:29 43 Views12 Replies Note: 360 degree servomotor works like a motor, you could control its speed and direction, but not angle.
hi i just bought it , why this servo always rotate? even the program closed? any sugestion? i used raspi 3
JaneYu Hi the weight of the motor is 60g including the cable connected to the motor.
JaneYu Is this a continuous 360 degree motor or does it rotate and stop at 360 degree? if it just 360 degree, is the motor able to be modified so that it rotates continuously?
JaneYu Yes, its a continuous 360 degree motor.
Can this motor be used with brushed ESC? im planning to connect it to the brushed ESC which will be connected to the receiver, no arduino will be used. Is that compatible?
JaneYu HI, I am sorry, there is no encoder for this motor now. And it is a 360 degree rotation servo. The control method is similar to the standard one, but work as motor.
JaneYu I understand that it does not have angle control, but does it stop on the dime, say my code specify an amount of time it runs, and stops, and does it hold its position.
JaneYu So...A motor specially designed for the robot arm or joints, shouldnt have angle control?... so u cannot really have any feedback from the position?
Thanks.
JaneYu
