Can someone compare this part to the common and cheap HC-SR04 ultrasonic sensors? I realize this is UART where the HC-SR04 needs a new library to operate, but the cost is enough to...
userHead JaneYu 2015-07-09 20:55:58 24 Views0 Replies
Can someone compare this part to the common and cheap HC-SR04 ultrasonic sensors? I realize this is UART where the HC-SR04 needs a new library to operate, but the cost is enough to make for that difference. What is the advantage of this?
