Hi! Can this camera work with Arduino Due (3.3V signal levels)?
userHead JaneYu 2015-07-14 19:45:03 23 Views12 Replies
2016-08-01 18:05:41
.Come posso realizzare questo grafico da Arduino a Processing?
Grazie
2016-07-28 00:02:33
Hello , I would like to know the intrinsic parameters of this positioning IR camera, such as focal length and distortion coefficient. Can you provide me the link if available?
Please check the camera datasheet. we're using the same camera with wii http://wiibrew.org/wiki/Wii...
2016-07-29 18:10:53
2016-07-05 11:41:19
Hi, the camera has a limit to the detecting range. What the camera caught is the infrared light, so in theory, it should be OK with other lens, but it is difficult to achieve.
2016-05-22 14:13:45
I just purchased the SEN-0158 IR camera and have some questions about detecting.
Are pullup resistors required for the I2C lines ? What resistance should these be ?
How do I get it to detect flames or other heat sources ? My test with the Arduino sample code showed there was no problem picking up an IR LED that was powered, but it repeatedly fail to see the heat signature of a soldering iron or the flame of a small handheld cooking torch.
How do I get the sensor to detect heat sources and not just electronic IR LEDs ?
Thanks!
This camera has integrated pull-up resistor, And what the camera real captured is the Infrared light, generally flame could radiate heat and light, it is wide-range wave length. but the iron won't
2016-05-27 16:09:16
2016-03-28 17:20:51
Hi this is IR camera module. it has been integrated all you need, just connect it to MCU I2C interface, The camera transmits location coordinate only, it is very fast.
Hi, thanks for the reply. Another question...What is the resolution of the camera? I know the Wii remote camera has 128x96 camera which uses 8x subpixel analysis to provide a 1024x768 resolution. Does this camera do the same, or is it just the 128x96 pixel resolution? Thanks
2016-04-06 19:50:21
2015-11-30 17:19:38
Hi Jape, it will output coordinates on X-axis and Y-axis
Hi, actually I bought one and I got it to output the X and Y coordinates aswell as the size of the marker, its intensity and the bounding box in pixels. Great product thanks!
2015-12-01 05:13:40
2015-10-04 03:38:36
Is there a way to change the default I2C address to run two cameras on the same bus?
2015-07-17 18:47:20
HI, we haven't tested it on DUE, It is better to add a resistor between IIC interface.
