Can anyone clarify for me; does the digital (signal) line need to be PWM at 38 kHz, or does this module generate the 38 kHz PWM?Thanks!
JaneYu 2015-07-17 04:03:34 20 Views2 Replies Can anyone clarify for me; does the digital (signal) line need to be PWM at 38 kHz, or does this module generate the 38 kHz PWM?
Thanks!
2015-08-21 10:34:14
JaneYu
This is an Arduino IR Transmitter.We haven't used it on RPi before. In theory it should be OK. But you need do some research for the tutorial.
JaneYu
