How do you attach the sponge part to the wall of the water tank?
userHead JaneYu 2015-07-29 16:31:54 17 Views10 Replies
2023-07-10 15:35:26
It is necessary to ensure that the distance between the plane where the sensor is located and your liquid is less than 3mm.
So we recommend that you use it sticked the cup wall.
2022-09-14 06:11:50
Can it detect wine in a wine bottle when filling almost to the top and what are the dimensions of the sensor?
2019-03-18 13:57:14
No, this sensor is by detecting the different capacities when there is water or not close to it.
2019-02-03 15:14:44
hello, I'm looking for a non-contact sensor for GASOLINE, I've tried several products of other manufacturers but no one seems to correctly detect gasoline level (only water). Is there any product of yours that can be in line with my needs?
thks in advance
The non-contact sensors we have are also only for water, we still don't have sensor for gasoline.
2019-02-12 10:07:43
2018-11-15 03:07:24
is it waterproof sensor i know that it can detect the water without the need to immersed it into water but let us suppose the water came on it does that will damage it
It is not a waterproof sensor, the water will damage it!
2018-11-15 14:51:09
2017-07-09 15:28:03
does the product sold in malaysia? hope to get the answer quick.
2017-02-09 13:29:43
Try their new one: https://www.dfrobot.com/ind...
2015-07-30 17:30:56
Hi, this is a conductive foam, with it could enhance the capacitive sensing signal.
