Hi , can i used this shield with Raspberry ? if yes is there a python library to manipulate it ?
userHead JaneYu 2015-09-05 19:27:40 8 Views5 Replies
2020-01-07 17:45:38
Hello !
It's not working with a PLC... Can you tell me how to use parity of rs485 protocol (none,even, odd ?) and if we have to use one or two bit of stop ?
thants a lot for help !
BR
Philippe
Hi, there is a link that I hope could help you.
https://wiki.dfrobot.com/RS...
2020-01-08 10:04:35
2017-04-24 22:18:23
Hello, I want to use Pt100 with analog sensor interface. Is that OK? Or which product i should buy? Thank you!
2016-02-05 05:07:15
Hello, what are the references of the connector for the analog sensors ? I do not find them in differents shops
2015-09-11 11:34:30
Hi, this is a 12V RS485 sensor node, I am afraid it doesn't support RPi, What is about this one? Does it meet your request? http://www.dfrobot.com/inde...
