do you have a table with what voltages the sensor should be outputting from different shades of gray? also what is the optimal reading distance for the sensor?
userHead JaneYu 2015-11-18 23:02:31 41 Views7 Replies
2022-09-01 21:19:18
What meas the values sent by the sensor ?
Hi, The value returned by the sensor is an analog quantity, which is different for different colors and can be used for simple color discrimination. If you need a high-precision color recognition sensor, we recommend this color sensor:
2022-09-22 11:25:07
2021-04-07 13:31:45
Could you tell me the model number of ambient light sensor attached on this module? According to your schematics, it is referred as a photoresister MG45-12, but I couldn't find any information of the photoresister having MG45-12 as model number.
2018-12-08 16:00:13
Compatible with the micro:bit?
Yes, it can compatible with the micro:bit, and you need connect the analog pins on the micro:bit.
2018-12-10 11:27:03
2015-11-21 14:32:10
I want to know how far should the sensor the surface being sensed for optimum readings?
1~3 cm will be the best range. or it will be interfered by the ambient light
2015-11-24 14:56:09
