Does this Board works with Arduino with 3.3 V logic?
JaneYu 2015-11-30 21:36:36 24 Views13 Replies Does this Board works with Arduino with 3.3 V logic?
Hello, I have energy meter with RS485 terminals. https://uploads.disquscdn.c...
Should I Connect to the A/B of the Shield or to the +/- of the shield?
Thanks,
JaneYu Hi, cuould you send us an email [email protected] with your photo of circuit connection, which will be helpful for us to help you.
JaneYu Hi I got this device it works well with modsim software. I used it with a device that uses modbus rs485 protocol. This device uses an ethernet (RJ 45) cable as an intetrface to transmit data. When I connected pin 4 to terminal A and 5 to terminal B on the shield, nothing happened. Only the Tx LED was blinking. I even connected pin 8 to the shield's ground, and interchanged pin 4 and 5 still no change. What can I do please? Thanks in advance
JaneYu Hi I would like to ask some guidance for reading ModbusRTU using this product, I looked around and tried but failed miserably, from Mikro DPM380 (http://www.itmikro.com.my/a..., while using SimpleModbusMaster.h (https://github.com/pepsilla....
The following is my Arduino code:
#include <simplemodbusmaster.h>
#define baud 9600
#define timeout 1000
#define polling 100
#define retry_count 10
#define TxEnablePin 2
#define TOTAL_NO_REGISTERS 2
unsigned int regs[TOTAL_NO_REGISTERS];
enum
PACKET1,
TOTAL_NO_PACKETS
Packet packets[TOTAL_NO_PACKETS];
// put your setup code here, to run once:
Serial.begin(9600);
modbus_construct(&packets[PACKET1], 1, READ_INPUT_REGISTERS, 4019, 1, 0); //FREQUENCY
modbus_configure(&Serial1, baud, SERIAL_8N1, timeout, polling, retry_count, TxEnablePin, packets, TOTAL_NO_PACKETS, regs);
// put your main code here, to run repeatedly:
modbus_update();
float frequency;
unsigned long temp = (unsigned long)regs[0] << 16 | regs[1];
frequency = *(float*)&temp;
Serial.print("requests: ");
Serial.print(packets[PACKET1].requests);
Serial.print("\n");
Serial.print("successful_requests: ");
Serial.print(packets[PACKET1].successful_requests);
Serial.print("\n");
Serial.print("exception_errors: ");
Serial.print(packets[PACKET1].exception_errors);
Serial.print("\n");
Serial.print("failed_requests: ");
Serial.print(packets[PACKET1].failed_requests);
Serial.print("\n");
Serial.print("retries: ");
Serial.print(packets[PACKET1].retries);
Serial.print("\n");
Serial.print("connection: ");
Serial.print(packets[PACKET1].connection);
Serial.print("\n");
Serial.print("frequency: ");
Serial.print(frequency/10);
Serial.print(" Hz");
JaneYu Hello,
I have a master which is a plc and has RS485 port and I'm communicating over MODBUS RTU PROTOCOL with several devices each device has his own ID and register addresses, If I use this board can I read variables from arduino and what will be the ID and the register addresses of arduino
JaneYu I have a load cell, the signal is RS485 and I need to read it with the shield in the arduino. (I have the shield) or i need reading example
JaneYu Hello. How will I be able to communicate with a modbus device? I have a relay through modbus that I want to send commands to, to toggle it on and off.
JaneYu Is your device use RS485 connector? This shield is converting RS485 signal to TTL/USB signal.
Yes,it is. R6 is the rs485 terminal resistor.
They are all VCC,GND,A,B. Just the connector is different. The standard connector is suitable for industrial devices, the mini-connector is suitable for URM04, and the pin header is suitable for DIY experiment.
JaneYu
RS485 Shield for Arduino DFR0259
