Can this arm be used under water?
userHead JaneYu 2016-06-11 23:43:10 50 Views5 Replies
2016-07-06 22:36:20
High torque continuous Servo motors provided with kit (DSS-M15 and DSS-P05) are not working with arduino can you please attach code snippet of Arduino code to drive above motors and provide soft copy of working code and libraries and detailed datasheets
These servos are the analog servo, the driving code has been integrated in the Arduino IDE, you can use the sample code to drive it: click the menu, Files>Example>Servo>Sweep
2016-07-11 13:10:41
2016-02-17 11:12:01
Sorry for missing the comments, the arm is a little big for Devastator tank. I am affraid it doesn't support.
2016-02-17 11:10:39
Hi, what is you power supply? is that a power issue? servos require huge current
2015-11-30 17:26:51
Hi Sheldon, it is about 250g, You could try to upgrade the servo if you want to improve its payload
