If it is advertised as a $69 Windows 10 Computer, why is it $89? #confused!?
userHead JaneYu 2016-01-20 22:20:21 7 Views35 Replies
2016-09-05 17:43:51
Can I add a SIM module with a GSM modem on this board? Thanks
2016-08-31 11:36:30
Is there a shipping date? do we have to preorder? Or do you have it in stock and where does it ship from?Can someone fill me in?
2016-08-30 10:57:27
Why does the 2g version come with a Win 10 product key and the 4g version does not. Hate to be lame but what problems with not have the product key cause me because I order the 4g model. Thanks
2016-08-30 10:08:13
If I buy the lattepanda 4/64 now will I have to wait till December to get it? I live in usa
2016-08-28 22:13:13
i purchased LattePanda 4G/64GB, everything works fine except when i install the Intel HD Graphics, the driver loads properly, but the windows won't open, as soon as the login screen comes up, and once i login, the screen suddenly dissapears, and the pc shuts off. The only workaround for it is to disable the graphics card. What would be the issue?
2016-08-24 15:56:13
Hi, on the store "LattePanda 2G/32GB with Win10 product key" is "Out of stock". Is it still available this product? Thanks
2016-08-24 09:28:26
Would you PLEASE include the fact that ONLY the 4GB/64GB model supports x64! I just purchased the $109 2GB/32GB so I not using the x64 environment I guess.
2016-08-10 21:46:17
What is the road map for this product? How long will it be in the market? Will LattePanda 2G/32GB always come with Win10 and its product key? Thanks
Yes. 2G/32G version will always come with win10 and its product key. Although a 2g/32g without win10 is available.
2016-08-16 09:40:03
2016-08-02 03:37:51
2016-06-18 23:43:25
it can work with Windows 7 ??
2016-06-07 08:26:13
how do u start the latte pANDA set by step please
2016-05-28 02:33:53
Diky za odpoved a informace. Chtel jsem si koupit Mini PC Latte Panda, ale kdyz vidim, co vsechno by me cekalo tak to asi necham byt.
2016-05-24 02:45:25
Hello, can i buy a LattePanda now? Or is it only a pre-order??
2016-05-23 18:13:01
Ahoj, ja jsem z Ceska. Jsme distributori DFRobot a mame cinskou pobocku.
2016-05-23 08:38:47
I odered it and its been 22 days it said it would take 20 so where it at
2016-05-22 15:14:15
Which type of USB do u use ?? Im using 5V/2A ..power supply with different usb cable. After my latte show windows screen within few seconds or clicking refresh the red light fade away nd shut down automatically.
I use lcd monitor with HDMI to VGA cable
I think it may the problem of your power supply.Please try other 5V/2A adapter with good qulity.We recommand http://www.dfrobot.com/inde... And you can find this by searching the keyword "lattepanda"
2016-05-23 11:56:55
JaneYu wrote: 2016-06-14 01:18:37 2 Replies
2016-05-18 05:28:53
Hello do you have Stock?, Thanks
2016-04-17 00:22:17
Where can I find the drivers?
2016-03-31 11:36:13
can u add a heat sink to it
2016-03-30 18:41:45
Please include Acrylic or plywood case , i will buy it
Sorry ,case is not included in pre-order. We will cooperater with LattPanda team and release Acrylicand plywood case ASAP
2016-03-31 16:41:01
