Is it possible to use this app with your BLE MICRO connected to any other arduno board (UNO, Leonardo) or will it only work with your BLUNO boards? (I mean uploading code via BLE)
userHead JaneYu 2016-03-21 21:58:55 8 Views15 Replies
2018-03-29 03:17:50
Hi. I'd really like to modify my beanForge app (https://itunes.apple.com/ph... so that it works with the Bluno controller. I am able to connect to the Bluno in Swift, and I can see how to send and receive data. I have a cloud compiler setup, so I can get a hex compiled version of the sketch. However, I can not find any function or method in the DFBlunoManager class that allows me to put the board into bootloader mode or to send the code to the board. It would be really helpful if you were able to guide me on this or if you were willing to share the source code for the BigBee app since what I'm trying to build is very similar to that.
2017-08-30 16:54:08
Hello
I dont understand. The service the software is referring to seems to be Bluetooth 4.0 related. So there is a problem between the Romeo BLE mini and BigBee.
Can you please look at this? I want to build robots for a class of children, but I cant before this works.
The problem is BigBee will not be continued , so you may meet the problem like can't find the sevice, there are other apps for BLE devices like Whendo and GoBLE. Do you want to build robots and program wirelessly?
2017-08-30 17:44:00
2017-08-19 13:46:46
OK I set it to slave mode with AT commands as instructed, but I still get "Service not found" on the iPad when I try to download an example.
2017-08-15 17:35:19
Hi all. I bought a Romeo BLE Mini and downloaded Bigbee to program it (iPad).
It powered up OK
The iPad connected to the Romeo BLE without problem.
When I try to download a program, it says "Service not Found".
How do I fix this?
Hi DFRobot
I am not getting responses on my support requests.
2017-08-17 05:02:04
When the message showed up, is your BLE still connected to BigBee? and please try to enter the at mode, make your BLE as a slave device
2017-08-17 13:36:21
2017-07-04 14:51:11
Hi Thanks for the prompt support. Installed and working appreciate your help
2017-05-17 05:06:03
Hello.
The app closes when I press upload. Tablet Bq Aquaris M10 Android 6.0.
Thanks.
2016-09-01 10:05:27
Does it work on bluno
i think it works on all bluno and bluno beetle
2016-09-01 10:07:15
2016-03-29 00:37:59
I can't save one program. The save button no appears.
2016-03-23 23:57:58
How can I save my programs?
2016-03-23 13:14:27
BLE micro are also one of our product, it will work with Arduino uploading,. But ATmega32u4 (Leonardo) are not in the supporting list, since Leonardo comes with USB port,
