Hi, I got this one, but there isn't any instructions of how to use the receiver (polarity?) nor how to connect it to anything (Arduino, for example?) Can you provide an example?
JaneYu 2016-03-28 13:06:11 11 Views3 Replies Hi, I got this one, but there isn't any instructions of how to use the receiver (polarity?) nor how to connect it to anything (Arduino, for example?) Can you provide an example?
2016-03-28 17:09:18
JaneYu
Hi, the receiver has been integrated in the small chip. the two pads are just output power positive and negative
JaneYu JaneYu
wrote:
2016-03-28 17:51:43 1 Replies
I used it, but no indication of the polarity (which is the positive and the negative). When I put a multimeter there, it gives me zero, as it seems that is not getting activated. Is the arduino a load to small? What is the specification for that?
