Even with the drawing I can't quite figure out the inside of the shell. I'd want to use a stepper so I could get 360 rotation. Does that seem feasible?
JaneYu 2016-03-29 06:55:56 11 Views2 Replies Even with the drawing I can't quite figure out the inside of the shell. I'd want to use a stepper so I could get 360 rotation. Does that seem feasible?
2016-08-21 17:06:25
JaneYu
It's the nature of the beast. With hobby servos you get either 180, or continuous rotation. but, while it won't work correctly in this case, you could also use a 1:2 gear combination to get full 360, or an encoder with a full rotation servo. Or use a stepper motor instead of servo, or a DC motor with encoder.
JaneYu 2016-04-14 22:29:11
JaneYu
I am afraid the stepper motor can't be installed inside, but you can check this 360 servo motor http://www.dfrobot.com/inde...
JaneYu
